Motor power inconsistent on a 2002 Dodge Ram 1500 Van
Old Nov 22, 2020 | 10:31 PM
If you have a scanner that can read live data, watch what coolant temp is doing the first ten minutes.
Old Dec 2, 2020 | 02:02 AM
Avishai Benyamini's Avatar
Avishai Benyamini
Thanks, HeyYou.
I connected a scanner and measured the coolant temp. It continuously increased to around ~190F.
Old Dec 2, 2020 | 07:25 AM
Ok, so that's as it should be.
Check the IAT sensor as well. (intake air temp)
Seems like once it gets fully into closed loop, it runs ok? 45 PSI is a bit low for fuel pressure, but, I think still within the acceptable range..... Can you monitor that while driving??
Old Dec 25, 2020 | 03:28 AM
Avishai Benyamini
Hi again.
I checked both the IAT and the fuel pressure and both ok.
I found some spikes from the distributor. I replaced it, the wires and some of the spark plugs I managed to remove.
Now the car doesn't start at all.
I verified the distributor position aiming at the 1st piston while TDC (top dead center)... Any ideas?
Old Dec 25, 2020 | 10:12 AM
I suspect the distributor is off. With #1 at TDC, there is a depression in the distributor body the rotor should be pointing at, and its more toward cylinder 2, than 1......
