Ram Van 3500 No Start :(
Old Jan 19, 2021 | 11:58 AM
Martin Hoisington's Avatar
Martin Hoisington
Default Ram Van 3500 No Start :(
Hello everyone,
I have a 1995 Dodge Ram Van 3500 with the 5.9L V8. I just replaced the distributor cap, rotor, spark plug wires, and spark plugs. I was wanting to give it a tune-up since it had been a while since it had one. My van ran for a day and then I went to start it this morning and it started for about 5 seconds and then died. I have yet to get it to start after that. I tested the battery which was found, then I tried starting fluid and with no luck, I also verified I had fuel pressure. I tested for spark by pulling a spark plug and grounding it to the engine and cranked the van, no spark.... I reinstalled the old parts and this did not fix my issue as I still have a no-start situation. What could I have done that has caused this, I feel stupid for trying to maintain my van and then end up breaking it. Thanks for all your ideas and help!
**Solved**
see below
-Marty
Last edited by Martin Hoisington; Jan 20, 2021 at 02:08 PM. Reason: problem solved
Old Jan 19, 2021 | 09:36 PM
What year is your van?
Check the wiring for the crank sensor, it's right behind the passenger side head. (yeah, gotta pull the doghouse again, if it isn't already off. )
Old Jan 19, 2021 | 09:57 PM
Martin Hoisington
it is a 95. And I'll check that in the morning, thanks!
Old Jan 20, 2021 | 06:39 AM
Busted Nuckles's Avatar
Busted Nuckles
I suspect something simple. The only thing you changed that would cause a no start issue might be the coil wire or possibly the cap and rotor not seated correctly. That would be my guess only.
Old Jan 20, 2021 | 09:59 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Use the wire from the coil to test for spark, doing so will take the distributor cap and rotor out of the equation.
Old Jan 20, 2021 | 02:10 PM
Martin Hoisington
I think that you were right. I ended up letting it sit overnight. This morning I took all the wires, cap, and rotor off. I then install all my new parts again making sure I had the spark plug wires right. Within 5 min of doing this, I had a running van again. It must have been something little I did along the way. Thanks for everyone's suggestions they all helped!
