2003 B3500 DRL's Stuck On
Old Jul 2, 2021 | 06:54 PM
GerriLynn's Avatar
GerriLynn
Default 2003 B3500 DRL's Stuck On
I have an 03 B3500 cargo, and has DRLs.
They are now stuck on, came on during the night, and killed the battery. If I connect the battery, the DRLs come on, without a key on or anything.
Is there a way to disable the DRLs? I have to connect/disconnect the battery anytime I use the van.
Old Jul 3, 2021 | 10:09 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
I don't know where it's located but there should be a DRL relay/module somewhere. (Possibly a black box next to the wiper motor.) Pull it and the DRLs should go off. In fact if the DRL relay/module is stuck on, that could be the problem. On a second note, if you have a factory security system in the van, there is a security relay that controls the same headlamp bulbs as the DRL does. If the security system has a problem, or if this relay is stuck on, then the lights will stay on all the time as well.
Here is the basis DRL circuit for these vans.
Old Jul 24, 2021 | 05:04 PM
GerriLynn's Avatar
GerriLynn
Does anyone know the location it would be at on this van? I can't figure out where the DRL module is and still having the issue.
Old Jul 25, 2021 | 10:54 AM
According to theory, the mdule is indeed next to the wiper motor, the relay, however..... is under the glove box??? (at least, that's what I found. No clue how accurate that is.)
