Dodge Ram B3500 van - front end recovery points
Old Jan 31, 2022 | 07:19 PM
Georges_Montreal's Avatar
Georges_Montreal
Default Dodge Ram B3500 van - front end recovery points
I have a 1995 Dodge B3500 RV conversion van (a Leisure Travel Freedom Widebody). I would like to add solid recovery points (such as tow hooks or shackles) on the front end of this heavy vehicle so that if I get stuck while light boondocking I can hook up a tow strap or chain with a hand winch to pull it loose. I have looked everywhere online for B3500 front end tow hook kits or in fact ANY suggestions on how to add recovery points for the front end of a B3500 van. I am avoiding the front end hitch receiver solution - can't find one made for this van anyway. Can't find anything for the 2nd gen vans (I do see many solutions for Ram 3500 pickups and the newer Sprinter vans). Any suggestions for tested, non-damaging and secure front end recovery setups for my 8500 lb. GVW van? If you get your Dodge B3500 van stuck, how would you set up your recovery gear (where/how do you attach it) to winch it forward from the front end?
Thanks
Old Jan 31, 2022 | 07:20 PM
Georges_Montreal
Front end recovery for these heavy RV vans is seemingly a topic never discussed in all the Dodge, RV, Class B, Roadtrek, LT, etc. forums. I had for quite some time been checking into a front-end receiver hitch but found none made specifically for the Dodge B3500 van. After all the research, I found only one B3500 van (that was not a super-expensive 4x4 conversion) with a front-end receiver and that one was hand fabricated by a hard-core mechanic/boondocker. There is tons of stuff for Dodge 3500 pickups but their chassis is completely different and based on a frame rail while the B3500 van relies on unibody and a subframe.
Since I am not going off-roading with this rig and only anticipate getting moderately stuck, I have been more recently looking at add-on tow hooks, various tow bridles, axle straps and so on, connected to a very strong equalizer strap which would then be hooked on to a very strong tow strap, pulled by a hand winch, then attached to an anchor point. I am not crazy about using the control arms as recovery points for fear of damage or causing misalignment, but pro recovery truck crews use such methods to pull forward quite heavy vehicles for short distances.
I just wish Dodge had built in strong, safe front-end recovery points for these vans.
In the absence of a better recovery solution, here is what I have come up with for a straight-line front-end recovery setup for the vehicle:
- 2 heavy axle straps, one looped around each control arm (unless I can add legit tow points)
- each axle strap is connected by a D-ring to each end of a heavy-duty equalizer strap
- the equalizer strap is attached via soft shackle to the primary tow strap
- the primary tow strap ( 20+ ton break strength) is connected by a D-ring to a ****** block on the cable winch
- the other end of the 4-ton cable winch is connected through another D-ring to the tree saver strap which is finally attached to the main anchor point
Any better ideas?
Rear end recovery should not be too bad with the rear hitch shackle adapter on the already-installed heavy-duty trailer hitch. My best bet is to altogether avoid any muck I can't back out of!
Old Feb 1, 2022 | 11:06 AM
I am not a fan of having metal objects in the middle of my recovery line. If something snaps, that d-ring is going to have a LOT of velocity, (read that: Energy) and is going to do some serious damage to whatever it hits. If that happens to be you.... well, vehicle recovery will instantly become the least of your worries.
Is the front subframe stout enough to bolt some hooks to? Or maybe some d-rings mounted via the bumper bolts? (assuming they come thru the front of the bumper.....)
Old Feb 1, 2022 | 06:43 PM
ol' grouch's Avatar
ol' grouch
I pulled several tow hooks off years ago, and over the years, I've bolted them to the frame just behind the front bumper.
Old Feb 2, 2022 | 01:24 PM
ElkCon's Avatar
ElkCon
I have had to use the bumper itself when I got stuck in the mud. We used a strap to pull it out.
