Strange noise when backing up cold
Old Feb 14, 2022 | 10:14 PM
Decodancer's Avatar
Decodancer
Default Strange noise when backing up cold
Since you guys were so great at solving my last issue, thought I'd pick your brain just one more time. When I back up my van after its been sitting overnight, I sometimes get a grinding noise . Once the van is warmed up, it's fine and it seems to only happen in below freezing temps. It never happens at the mechanics shop of course so he can't diagnose it. It almost sounds like a power steering belt to me? The van had a new transmission installed a year ago so unlikely that it's that. Just want to make sure it's nothing serious. Thanks for your help. 2000 Ram 1500 5.2
Old Feb 15, 2022 | 10:51 AM
Can you tell from about where the noise is coming from?? It might be as simple as rust buildup on the rotors being scraped off......
Old Feb 15, 2022 | 11:23 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Tonight back the van in instead of pulling it in forward and see if it does the same thing going forward first thing in the morning. If it does, then like HeyYou said it's just overnight rust build up on the rotors.
Old Apr 14, 2022 | 09:02 PM
Cotten's Avatar
Cotten
Default Me too
I have a 97 dodge B2500 that does that also. I bought it with about 220,000 miles on it. Its currently at 333,000. Put a rebuilt trans at about 240,000. I guess the noise started around 300,000, like a whining in the trans, maybe from higher hydrollic pressure from cold fluid. I do know it likes clean trans fluid and is less noticeable after a change. I don't stress it until it warms up, and like you said, I back in if I know its gonna get really cold, (if I remember to) or give it time to warm up before I set out. Guess this isn't any help, but I would also like to know where that noise comes from. Good luck.
