Engine randomly dies - 97 Dodge b3500 5.9 gas-
Old Jul 10, 2022 | 10:02 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by Moparite
I see you posted another post about this, You should keep it under this post as others may not know the posts here on it. It sounds like you have multiple issues.
I combined the two threads so that there is only the one thread now.
Old Jul 10, 2022 | 10:05 AM
alloro's Avatar
alloro
Originally Posted by 97Dodgestationwagon
so i kept it in park and gave it gas for a while,took it for a drive and eventually it smoothed itself out? now it is running fine and giving me no stalls or rapid power outages or gauge drops.....i can go out there now and it will start up quick and idle smooth.. is this something that the computer automatically relearns when installing a new ignition switch module?
That happens to me every time I disconnect power and the PCM powers down. So yes it seems to be a relearning the idle thing.
Old Jul 10, 2022 | 11:29 AM
97Dodgestationwagon's Avatar
97Dodgestationwagon
I see you posted another post about this, You should keep it under this post as others may not know the posts here on it. It sounds like you have multiple issues. Get the fuel pressure tested, It wouldn't hurt to drive around with it on there either to see if the pressure drops then comes back up. A bad crank sensor can fail(not giving a signal to the pcm) and will cause the engine to die(while driving). Third the plenum gasket fails on these engines and can cause stumbles/backfires and loss of power. Lastly if all others check out your IAC may be on it's way out. This will cause the engine to die after first start.
So what about the driver door buzzer, and the door lock switches not working? wonder why they stopped working when all of this happened.
Old Jul 10, 2022 | 12:08 PM
Door locks should be powered at all times. I think there is a circuit breaker for those..... but, not 100% on that. Do your dome lights come on when you open the doors?
Old Jul 10, 2022 | 07:58 PM
97Dodgestationwagon
yes the dome lights come on. the buzzer and door locks went out at the same time, are they both fed off the same power?
Old Jul 11, 2022 | 07:48 AM
Not sure. I don't have wiring diagrams for the vans, and if it's a conversion van, all bets are off.
You can try looking them up here, see if its useful.
Old Sep 1, 2024 | 01:38 PM
Dontknownothin's Avatar
Dontknownothin
Did this issue ever get fixed? This happens to me only in the mornings but then runs fine all day.
Old Sep 18, 2024 | 12:04 AM
97St.Wagon3500's Avatar
97St.Wagon3500
This problem ended up being my ignition switch. Another issue I found was wires shorting on top of engine from getting hot and plastic sheild wearing off of them.
Old Sep 28, 2024 | 10:49 PM
Lahjim's Avatar
Lahjim
Can you tell me where exactly were the wires shortings? I have the exact problem you are describing but I haven’t found my problem yet and the very last thing I have to check is the wires but I don’t know where to start. THANKS
Old Oct 7, 2024 | 09:17 PM
97St.Wagon3500
the ignition switch was bad and fixed my problems when i replaced it. Altho the wires shorting were behind the driver side door panel, if you have power locks and windows. The 2nd short I found was under the doghouse in the engine bay where all of the wires are wrapped together. Specifically the wires coming off the pickup plate (under the distributor cap) these wires lead to a wrapped cluster. Check those.
