Air conditioning Issues
Old Jul 31, 2022 | 05:53 AM
CanuckRV's Avatar
CanuckRV
Default Air conditioning Issues
My 97 3500b's air conditioner coil seems to be freezing. When I start out I get lots of cold air with a good airflow from the vents. over the course of a couple of hours, I get very little airflow and only slightly cool air. The pressure in the system according to a gauge on a refill canister is where it should be so I did not add any.
I think the rad inside of the heater compartment is getting clogged with ice. If I run the vent for a while and then switch back to AC I will get some more air but the whole cycle starts over. How can I fix this?
Thanks
Old Jul 31, 2022 | 09:59 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
The condensate drain tube/hole is likely clogged and allowing water to build up and freeze. Clear the clog and the issue should go away.
Old Jul 31, 2022 | 10:41 AM
CanuckRV's Avatar
CanuckRV
Tube is clear
Could it be the freeze sensor? How would I check?
Old Jul 31, 2022 | 10:56 AM
Does it have one??
Old Jul 31, 2022 | 11:17 AM
CanuckRV's Avatar
CanuckRV
No idea the Haynes I have says on later models there is on I don't know when later models start.
Old Jul 31, 2022 | 11:22 AM
Can you get access to the evaporator core, without having to disassemble the entire van? Might be worth taking a peek, and cleaning out any debris the inevitably collects there....
Old Jul 31, 2022 | 11:37 AM
CanuckRV's Avatar
CanuckRV
I just checked there are wires going into the cowling where one should be how would I check to see if working? and where would I find a part number?
Old Jul 31, 2022 | 11:47 AM
CanuckRV's Avatar
CanuckRV
I found the part number can I change it without draining the AC fluid?
Old Jul 31, 2022 | 06:12 PM
Not seeing that sensor on the wiring diagrams.
When is the last time you had the a/c system serviced? Freezing up appears to be a symptom of being low on refrigerant.
Old Aug 1, 2022 | 03:49 PM
CanuckRV's Avatar
CanuckRV
I will have a shop look at it I have a gauge that comes with the refill can it showed in the green so I didn't put any in.
I have no idea what the previous owner or her mechanic did so I think a professional is in order.
