Tune up recommendations
I'm about to hit 100,000 on my 2000 B3500. The last service was at 70K. The Dodge service manual says simply:
1. Is there anything else I should have done?
2. How can I determine if the cap and rotor needs replacing? The mechanic says if he has to check it he might as well replace it.
3. He's asking $400 just to replace the spark plugs (in big-city Pasadena, California). Does that sound like a reasonable price?
- Replace spark plugs
- Inspect PCV valve, replace if necessary
- Inspect distributor cap and rotor
- Inspect auto tension drive belt
- Lubricate brake booster bellcrank pivot (linkage)
What's his labor rate? Probably takes him longer to get TO the plugs, than it does to actually change them.
One of the problems with vans...
To check the distributor cap, you take it off, and look inside..... if the terminals look crusty, replace it, and the rotor.
I would have a long hard look at the plug wires as well. If they are original, it's past time for new ones.
When was the last time the trans was serviced?
One of the problems with vans...To check the distributor cap, you take it off, and look inside..... if the terminals look crusty, replace it, and the rotor.
Ignition wires, plugs, and rotor were replaced in 2017 at 70K. The service manual calls for wire replacement at 60K and 120K.
Radiator flush, new thermostat,air filter, transmission fluid, gasket, and filter, all at 100K (I'm at 104K now).
Yeah, the 400 bucks probably isn't unreasonable then..... Be sure to stick with standard copper plugs, whatever brand you prefer. These engines don't like the rare-earth fellers.
Firing order is printed on the manifold. (actually, I think it is cast in.... but, its in front of the throttle body, so, might be hard to see in a van.) Number 1 is marked on the cap, rotation is clockwise. 1 8 4 3 6 5 7 2. If you switch a couple, you will know IMMEDIATELY the first time it shifts into O/D.
(don't ask how I know.)
Did they adjust the bands in the trans as well? (part of the recommended service, not every shop is aware of that though.)
(don't ask how I know.)Did they adjust the bands in the trans as well? (part of the recommended service, not every shop is aware of that though.)
Not to be a smartass but yes, you could've looked up how to do it yourself. If you spent $50 on materials and another $50 on the needed tools you could keep a good $300 in your pocket. Changing spark plugs, or a cap and rotor isn't rocket science. It takes me about an hour to change mine (V6) so I don't see why you couldn't do it in 2-hours or so. That's like paying yourself $150/hour. There's plenty of knowledgeable people around here that could talk you through it if need be.
