Fan motor speed issue
Old Aug 27, 2022 | 08:02 PM
Islandcruiser's Avatar
Islandcruiser
Default Fan motor speed issue
I have a fan that only works on three quarter speed, if I advance the dial to highest fan speed it cuts out. I changed the blower module? under the hood but still the same issue? Any ideas how to resolve this I would love to get more air conditioning blowing
Old Aug 28, 2022 | 09:56 AM
What are you working on?
Old Aug 28, 2022 | 10:41 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
For many models there is a high speed blower relay which kicks in just for the high speed. The relay could be the issue.
Old Aug 28, 2022 | 11:09 AM
Islandcruiser
Sorry I should have known to put that info. 2000 B3500 Dodge Van 360 engine.
Old Aug 28, 2022 | 11:10 AM
Islandcruiser
Thank you that is good info I will check for a relay issue.
Old Aug 28, 2022 | 11:37 AM
Islandcruiser
I found the 50 amp relay and switched it out with another 50 amp relay from battery 1 but it did not help and looks ok, although i could try a new one later?
Old Aug 28, 2022 | 11:53 AM
Looks like there are two relays for the blower motor, one feeds power for the lower speeds, the second one is for high. Have you check the blower motor resistor block?
Old Aug 28, 2022 | 01:19 PM
Islandcruiser
Yes I changed out the old resistor block for a new on and changed the relay, no luck. I have found out the ac was not working and someone cut out and bypassed the high limit resistor to get it running again. Not sure if that has anything to do with it, or if that will cause other issues.
Old Aug 29, 2022 | 08:50 AM
alloro's Avatar
alloro
Could also be a bad speed selector switch.
Old Aug 29, 2022 | 02:26 PM
Islandcruiser
Thanks that's what I will try next
