Transmission swap
Old Dec 10, 2022 | 03:47 PM
SteveG102's Avatar
SteveG102
Default Transmission swap
have a 2001 Ram 2500 Van with 5.2L and 2wd transmission. The transmission went out and I got what I thought was the same from a scrap yard. After closer inspection the only difference I can find is the wire connection where the shifter linkage is. The one I took out had a five wire plug and the one I got only has a three wire connection. Can I swap them out or eliminate two of the wires??
Old Dec 10, 2022 | 05:31 PM
Trans you got is too old. Range sensor will be only the beginning of the problems Chances are good, the electronics inside the trans won't match up either.
