4000lb front axle
Old Feb 13, 2023 | 09:07 PM
Jcpup's Avatar
Jcpup
Default 4000lb front axle
97 b3500 need passenger side front hub it's a 4000lb front axle anyone know where to find?? I can't
Old Feb 14, 2023 | 11:40 AM
Rock auto has these as well. Apparently, you have replaceable bearings in there, inner, and outer. I bet your local parts store has 'em on the shelf.
Old Feb 21, 2023 | 09:38 PM
ElkCon's Avatar
ElkCon
the hub on the vans is the brake rotor
1999-2003 Dodge Ram 3500 Van Brake Rotor - Pronto BR5398 - Front - PartsGeek.com
if you are talking about the steering knuckle - yea that's gonna be a hard one to find
Old Apr 16, 2023 | 09:42 PM
Duffy7062's Avatar
Duffy7062
Angry Dodge ram van
Dodge ram truck and Dodge ram van have a 4000# axle but the hub and Rotor assembly will not fit a 97 B3500. Bearings do fit but the races which come with the assembly at too close together so axle nut will not tighten. I have had that assembly and as I said the axle nut will not tighten because the races are about 1/4 inch too close together I am still looking my 97 B3500 has been sitting for 6 months unable to get a safety for re registration.
Old Apr 17, 2023 | 09:50 AM
jeffersonracing's Avatar
jeffersonracing
What about adding some washers to take up that space so the nut will tighten?
Old Apr 17, 2023 | 08:52 PM
Duffy7062's Avatar
Duffy7062
I am looking into having rings made to put behind the races so the races are the exact distance from the front and rear of the assembly as the old one?
Old Apr 17, 2023 | 08:54 PM
Duffy7062's Avatar
Duffy7062
