Upper and lower control arms bushings
Old Apr 13, 2023 | 05:11 PM
sealow's Avatar
sealow
Default Upper and lower control arms bushings
Do I need to get an alignment done after changing the upper and lower control arm bushings? I know, that is a requirement, if the tie rods bushing are change.
Thank you, and be safe
Old Apr 13, 2023 | 05:30 PM
2 or 4 wheel drive?
Disregard that. I seriously doubt your van is 4wd.... So, yeah, you are gonna want an alignment after changing them.
Old Apr 13, 2023 | 05:54 PM
sealow's Avatar
sealow
2wd. Thank you.
Old Apr 15, 2023 | 08:46 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Yes, absolutely.
Old Apr 26, 2023 | 08:59 PM
89RamVan's Avatar
89RamVan
Just to add: The caster & camber are adjusted by the control arm bolts. Tie rod ends adjust toe-in. 3rd vote for YES on the alignment. I did it for mine, but it was a complete control arm job with arm, ball joint, & bushings installed as 1 assembly. GL
