Coolant Sensor Location
Old Oct 17, 2023 | 06:53 PM
Salsapants's Avatar
Salsapants
Default Coolant Sensor Location
I have an 86 B350 with a 360 motor. Trying to find the location of the coolant sensor, but after days of searching online I can't find anything that shows me where it is at. The temp gauge maxs out as soon as I turn the key in the ignition. Any help is greatly appreciated!
Old Oct 17, 2023 | 07:23 PM
jeffersonracing's Avatar
jeffersonracing
Far as I know they are always next to the thermostat in the coolant crossover part of the manifold.
Old Oct 17, 2023 | 08:38 PM
Salsapants's Avatar
Salsapants
Ok. Ive seen it then. But, there's two bits there. One has two plastic nipples on it and the other has three. Which one is the correct one? And how the heck am i supposed to be able to get that thing out? Tried getting a wrench in there but there's next to no room.
Old Oct 17, 2023 | 08:54 PM
jeffersonracing
That bit about the plastic nipples confuses me. The temp sensors should have wires connected to them.
Old Oct 18, 2023 | 07:07 AM
You might have two temp sensors, one for the gauge, with will be a single wire sensor, and one for the computer, which should be a two wire sensor..... On the magnum motors, one is right next to the thermostat housing, and the other is on the passenger side of the intake, in the front coolant crossover, right near where the heater hose attaches. Being yours is an LA engine...... they may or may not be in the same positions.
Old Oct 18, 2023 | 08:37 PM
Salsapants's Avatar
Salsapants
So it's weird. If I take off the breather, I can kinda see two things in the area next to the thermostat housing. One of them has what looks like three "nipples?" and a rubber boot that goes over it, and the other has two with a similar rubber boot. Looking at coolant sensors online, the bottom part that threads in looks similar to the bottom part of whatever is in next to my thermostat housing. I'll try to get a picture tomorrow, as I know it doesn't really help much.
Old Oct 19, 2023 | 06:55 AM
Those are probably vacuum switches.... (of the thermal variety) Temp sensors will only have wires. No vacuum line.
Old Oct 19, 2023 | 06:05 PM
Salsapants's Avatar
Salsapants
So Im fairly certain I found it. But, it looks like the wire has gone missing. By looking at it, it needs a 90 degree rubber boot, but where can I find a replacement wire?
Old Oct 19, 2023 | 06:08 PM
jeffersonracing
If you go to a pick and pull you can cut one out there and splice it into yours.
Old Oct 20, 2023 | 07:05 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
According to Rockauto, this is the temperature sensor pigtail. Does it seem to match what you need?
https://www.rockauto.com/en/catalog/...connector,2564
