1998 B1500 5.2 rough idle
Old Oct 25, 2023 | 04:46 PM
1996 B2500's Avatar
1996 B2500
Default 1998 B1500 5.2 rough idle
Having a persistent rough idle issue in my 1998 B1500, with the 5.2. When I drive it on the highway, it has good acceleration and power. I took it up on the interstate and it had no problem maintaining 75 mph. But in town driving it will have slight hesitation, and has rough idle. All underhood sensors (including oxygen sensors have been replaced, no check engine light or stored codes. Intake gaskets also replaced. Engine compression is good.
What could be causing this?
Old Oct 25, 2023 | 06:39 PM
jeffersonracing's Avatar
jeffersonracing
Injector cleaner, iac cleaned, throttle body cleaned, new spark plugs, cap and rotor. Anything related to a tune up would be where to start
Old Oct 25, 2023 | 08:22 PM
1996 B2500's Avatar
1996 B2500
I cleaned the throttle body, has new plugs wires cap and rotor. I put 2 bottles injector cleaner in it, , New IAC,TPS, MAP, coolant temp sensor, air charge sensor, both Oxygen sensors
also cam and crank sensors
Old Oct 26, 2023 | 09:31 AM
What plugs did you install?
Old Oct 26, 2023 | 10:22 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
1. Test fuel pressure
2. Do either a compression or leak-down test.
Old Oct 26, 2023 | 02:40 PM
1996 B2500's Avatar
1996 B2500
I installed Champion RC12YC4, as called for on the underhood label.It had Champion #7436 platinums when I bought it
Old Oct 26, 2023 | 08:57 PM
1996 B2500's Avatar
1996 B2500
Has new pump/regulator assembly. Pressure good. Compresson 115 psi all cyls. Very odd issue, as when I tromp down on it it takes right off with no hesitation and good power
Old Oct 26, 2023 | 09:02 PM
jeffersonracing
Might start checking for vacuum leaks. They would be more noticeable at idle.
Old Oct 26, 2023 | 09:37 PM
1996 B2500's Avatar
1996 B2500
That's what I was gonna check next, maybe there is a broken vacuum hose/line somewhere. I can rule out the intake gaskets as I replaced those
Old Oct 26, 2023 | 09:44 PM
jeffersonracing
Did you address the plenum plate when the manifold was off?
