Transmission options
Well - after doing the wheel bearings...yea I had a bad one...but the some of the vibration is still there...
It happens at 1600-1700RPM and at around 2000....
It feels like the torque converter or something in the drivetrain is vibrating...when I take i out of gear, yea -- yea - it goes away
Sooooooo at 200k+++ miles and driven everywhere from Chicago to Boston to Dallas and all over Florida, towing a 6000 trailer at times, well it may be time for a tranny...
Here is some of the help I need...is this the TC vibrating? Or is it a clutch pack? Is there any way to really tell?
I really dont think a fluid swap would help...probably make it worse - right? Fluid condition is pink...and no burn smell.
I have a few good lines on a few rebuilds...they are quite expensive though...the stage 2 build I want is 3100...that is with core trade...
Anyone know of anyone good that does them cheaper? It is getting hard to affordability in anything anymore.
I havent ruled out a u-joint yet...but the shimmy/vibration is fairly strong in the wheel and floor...
I check it out this weekend...but at 200K++ I think a trans may be needed soon...
Would the TC feel that way?
On my old truck, I did a tuneup, made sure I checked firing order three times...... and still got it wrong. So, I had two dead cylinders. You could barely notice it in the first three gears, but, once it hit O/D, it felt like the truck was trying to shake itself apart...... Don't feel it much thru the steering though. That kinda points to a front suspension problem....
