alternator drawing power drains battery
Old Mar 1, 2025 | 02:06 PM
tjpautzke's Avatar
tjpautzke
Exclamation alternator drawing power drains battery
I have a 1994 dodge ram b350 pleasure way camper van and it became a winter home for the squirrels last fall. they built full winter nest up in the engine compartment. now I am having electrical problems. I checked wire harnesses, replaced battery and alternator, but when I start the van the small negative battery cable gets hot to the touch and the alternator draw juice instead of charging the battery... I can run it for about 5 minutes before the battery dies and the engine shuts down...
does anyone have any ideas where to look next?
Old Mar 1, 2025 | 10:28 PM
You still have a short somewhere.... Time to go over the wiring again.....
Moving this to the Van section for ya. Welcome to DF.
Old Mar 2, 2025 | 07:34 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
When that smaller wire gets hot like that, it means the big negative cable has lost connection down on the engine block.
