More stuff to do - fuel pump
Well - 10 years out of a fuel pump...I guess that isnt that bad
My van has been stumbling a little..then I got code P0171 - LEAN....
then yesterday (I did this on purpose) the tank got down to 1/8 and the van would stumble a lot...so Im thinking - yep fuel pump (Ive done everything else lol)
Ill be starting on it in a few mins...anyone want a pic or have any ?s - just ask...it is a pretty straightforward job...IIRC taking the tank down is two nuts...after disconnecting the filler hose...
Then there is a large nut that holds the fuel pump on to the tank...that's it
I used an Herko 10 years ago...Ill see how their quality has changed
At least for my 2000, 3.9L, 1500, Herko has the standard size fuel pump and then they have one for the 35-gallon tank, each is a different part number.
Standard size: Herko Fuel Pump Module 179GE For Dodge B1500 Ram 1500 Van Ram 2500 Van 1998-2002
35-Gallon size: Herko Fuel Pump Module 191GE For Dodge B1500 Ram 1500 Van Ram 2500 3.9L 98-03
Its the 31gal -- it fit great - I had the 17ge
going to test it right now...one thing that was weird (I didn't check) was that the straps go in different holes in the body...not the same ones
