Need the Pinout for the ECU on a 1995 Dodge Ram Van B3500 5.2 Gas Please :)
Old May 18, 2025 | 08:40 PM
chatvmax's Avatar
chatvmax
Default Need the Pinout for the ECU on a 1995 Dodge Ram Van B3500 5.2 Gas Please :)
1995 Ram Van B3500 5.2 Gas,
I would deeply appreciate the following :
ECU wiring Pinout,
ECU Flashing light codes sheet,
ANY guidance on replacing the ECU Plug and Pins
Does this motor have a CAM and a CRANK sensor....?
Thank You in advance
My ecu says that there is no signal from the cam sensor ...
I replaced the crank sensor and really want to look at BOTH the crank and the cam sensor signal back to the ECU...
Old May 19, 2025 | 09:43 AM
Cam sensor is also called the pickup-coil. It's under the distributor cap.
Should be able to find wiring diagrams here.
Why do you want to replace the ECM connector???? Not a trivial undertaking..... Might be easier just getting a replacement wiring harness.... You won't find one new though..... Used is likely your only choice there.
