Are the steering wheel splines keyed?
Old May 20, 2025 | 10:09 AM
Cooreman's Avatar
Cooreman
Default Are the steering wheel splines keyed?
I replaced the steering box with a used one and now my wheel is out 1/4 turn. I would pop the shaft off and center it that way but there isn’t enough room to compress the shaft with out pulling the box. The drag link has staked ends so before I go adjusting the tie rods and screwing around with the alignment I was wondering if I could just pop the steering wheel off and put it back on.
it’s a 1988 b350
Old May 20, 2025 | 10:38 AM
it’s a 1988 b350
You don't wanna do that, as you would risk smoking the clockspring that is under the steering wheel. It will only turn so far, and if you go past that, it breaks, and yer done.
Old May 20, 2025 | 05:52 PM
Busted Nuckles's Avatar
Busted Nuckles
Those splines usually have a double spline that needs to be aligned with the mating part so you cant "knock it out of time."
Old May 20, 2025 | 08:06 PM
So far as I know, the part where the intermediate shaft hits the steering box, is NOT keyed..... and you *should* be able to pull it without dropping the steering box.
Old May 21, 2025 | 05:33 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Is it even possible to do this, or does the shaft only fit one way? If it were me, I'd of course first confirm the shaft is fitted correctly. If it is, then rotate both tie-rod adjusters the same until the steering wheel is straight, or bring it in for an alignment and have the shop do it.
Old May 21, 2025 | 11:11 AM
Cooreman's Avatar
Cooreman
On this van it is impossible to pull the steering shaft off with out taking all the box bolts out and dropping the box. I don’t think a 1/4 turn would break the clock spring, I’ve already had it cranked both directions being out a 1/4 so It should technically have turned more one direction already.
I guess I’ll just wait till I can have my van down for a bit.
Old May 23, 2025 | 09:41 AM
ElkCon's Avatar
ElkCon
did you put the pittman arm one tooth off?
Old May 26, 2025 | 03:55 AM
MaxKo's Avatar
MaxKo
Can confirm that!
Hat to turn my Shaft by one step, because of much many play, but then noticed that the steering wheel has a central key. So my steering is about 1 hour offcenter :-)
Old May 27, 2025 | 10:12 AM
Cooreman's Avatar
Cooreman
I pulled the box off a wrecker van had no keys so I couldn’t turn the wheel. I never pulled the pitman arm off oddly enough that’s the one tool I don’t own. So the box to steering wheel isn’t 100%
honestly If it wasn’t such a problem to realign the shaft I’d do that. It’s basically an interference fit for the shaft to box so I’d have to pull the bolts and hopefully have enough play in the lines and swear lots.
if I get real sick in the head I’ll pull the box grind the shaft out of the box so the steering shaft can slide on and off with out dropping it. Won’t need much to gain the clearance
