We've got a whole new set of problems - 91 B250 with TBI 318
Old Jun 15, 2025 | 01:31 PM
  #21
Ray Bell's Avatar
Ray Bell
Throttle body injection, not port injection...
Oil usage now absolutely minimal.
Old Jun 15, 2025 | 02:09 PM
  #22
Ooops. 91. Missed that.
Can you watch the spray pattern from the injectors? See if it stays pretty similar left/vs right, as you open the throttle a bit? One of them spraying nice, and the other kinda dripping will give you some odd results.
Old Jun 16, 2025 | 06:00 AM
  #23
alloro's Avatar
alloro
Van & CUV Section Moderator
If you look down into the throttle body with the butterflies open, does it look oily? If so, you could have the infamous plenum gasket issue sucking oil into the intake plenum, which in turn allows oil to get down into the cylinders.
Old Jun 16, 2025 | 09:38 AM
  #24
I don't think he has a two-piece intake. His is TBI, and I think it's a dual-plane intake.
  #25
Ray Bell's Avatar
Ray Bell
Now that is something I can check...
Does that problem produce the issues I have, rough running, power loss and undue fuel consumption?
Old Jun 16, 2025 | 10:37 AM
  #26
Yep. Burning oil fouls the plugs, and O2 sensors, clogs the cat, and a host of other fun things if it goes on too long.
Old Jun 16, 2025 | 10:31 PM
  #27
Ray Bell's Avatar
Ray Bell
I'll go buy a gasket set tomorrow and have a good look at whether or not it's prudent for me to get my hands dirty with this job on my own...
I have a mobile mechanic I can call in if I need, but I'd rather do it myself.
Is there anything else in the way of parts I'm likely to need? Once I start on the job I'll likely be immobile until it's done.
Old Jun 16, 2025 | 11:21 PM
  #28
Ray Bell's Avatar
Ray Bell
Went checking on youtube to see if I could learn anything...
The only video about the TBI manifolds is about changing to carburettor. Lots of stuff there on the Magnums. Lots.
Old Jun 17, 2025 | 09:09 AM
  #29
The kegger manifold is the one with the steel pan on the bottom. Two-piece intake. TBI doesn't have that.
Old Jun 17, 2025 | 03:50 PM
  #30
Ray Bell's Avatar
Ray Bell
Yes, I see that...
This is a fairly ordinary manifold, gaskets to the head surface and a gasket on the base of the TBI unit.
So where does it suck in the oil? At the head surface gasket?
Next point of interest is that NAPA cannot get these gaskets (no listing whatever) and O'Reillys have them only to special order - if they can get them, I'm waiting on a call.
What are my prospects of ever getting to the bottom of this?
