Ignition Coil
Old Sep 6, 2025 | 12:27 AM
arty4444's Avatar
arty4444
Default Ignition Coil
2001 DRV 3500 5.9L
I have the factory service manual for my van and no mention of the coil appears in the maintenance schedule.
I replaced the coil a few years back (almost 30K miles ago) and have no ignition problems at all. I'm about to replace the spark plugs, spark wires and distributor cap w/rotor for regular maintenance. How often, if at all, should I replace the coil?
Thanks in advance.
Old Sep 6, 2025 | 08:45 AM
Moparite's Avatar
Moparite
When it goes bad. It doesn't need "maintenance".
Old Sep 6, 2025 | 12:26 PM
This.
They are notoriously reliable, and generally last longer than the car they are bolted into.
Old Sep 6, 2025 | 01:32 PM
arty4444's Avatar
arty4444
Thanks,
””notoriously reliable””- That’s not something you run into too often.
Old Sep 7, 2025 | 08:30 AM
Moparite's Avatar
Moparite
There are some aftermarket ones that don't last, Accel being one of them. Ask me how I know!
Old Sep 8, 2025 | 03:34 PM
ElkCon's Avatar
ElkCon
Ive never had one go bad - now on my old 5.4 Ford yea all the time - my magnum 360 - never had an issue...
I have used Herko before and it has been on there for 5 or so years now...maybe I should swap it out - therye cheap
Old Sep 9, 2025 | 11:40 AM
arty4444's Avatar
arty4444
My current coil is aftermarket. I won’t bad mouth Duralast here but…
So when a coil does begin to go bad I assume the engine starts running rough. Would you know off hand if there is a coil trouble code?
Old Sep 9, 2025 | 06:07 PM
There is, but, what criteria it uses to set is a mystery to me. Easiest way to see if it's a coil problem, is put an inline spark checker on it. Spark should be uniform, and consistent.
Old Sep 9, 2025 | 06:29 PM
Moparite's Avatar
Moparite
You need measure resistance across the terminals of the coil(specs are in the service manual) if they are not with in spec it's time for a new one.
