Dodge ram van 1500 5.2 alternator excitation voltage and current
Old Mar 22, 2026 | 09:49 AM
  #21
So why is an external regulator not working? Seems to me, that would be the way to go. Numerous others have made the conversion successfully......
Old Mar 23, 2026 | 03:11 AM
  #22
tundrawolf's Avatar
tundrawolf
I will try and do some work to establish a proper excitation base voltage,
It seems 1.5 volts is a decent all around baseline, if you were in an emergency, it would not let the battery totally die
If I am able to, I want to take some alternators apart and test the winding voltages, thankfully the output voltages are relatively the same across all modern alternators, so I only need to be concerned with the field/excitation voltage
Old Mar 23, 2026 | 08:58 AM
  #23
tundrawolf's Avatar
tundrawolf
Is it possible to activate 4th gear using a switch or series of switches, when the shift lever is in D(rive) ?
Old Mar 23, 2026 | 09:11 AM
  #24
PCM just grounds a solenoid for fourth gear. (overdrive) There are some requirements before it will though.... Vehicle speed being right up there on the list.
Old Mar 23, 2026 | 09:51 AM
  #25
tundrawolf's Avatar
tundrawolf
So you know which wire to ground? I'm already having to manually shift, and I have a long distance to go, the engine really revs high even at just 45 mph, it would waste a lot of fuel
Old Mar 23, 2026 | 10:10 AM
  #26
Pin 6, possibly a brown wire down at the trans. At the PCM, should be connector B, pin 21.
Old Mar 23, 2026 | 10:24 AM
  #27
tundrawolf's Avatar
tundrawolf
*Do not so
I REALLY appreciate it!!!
Old Mar 23, 2026 | 11:10 AM
  #28
*Do not so
Real question is though, why does your trans not want to shift?
Old Mar 23, 2026 | 11:42 AM
  #29
tundrawolf's Avatar
tundrawolf
I am working on it now,
Do you happen to know how much current is drawn on that wire? I have smaller toggle switches I may have to buy a larger one
Old Mar 23, 2026 | 11:48 AM
  #30
Likely less than 5 amps..... but, that's just a guess.
