Still getting BRAKE and ABS lights on dash
Old Apr 10, 2026 | 08:40 AM
Originally Posted by OregonApe
2. I think anyway. 2 wheel drive. Front disc brakes, rear drum, I think.
RWAL will just have a dump valve, 4WAL will have the motor controller.... and also front wheel speed sensors.
Old Apr 10, 2026 | 11:28 AM
OregonApe's Avatar
OregonApe
So if I'm rear wheel drive then there are no sensors which means either I have a bad abs module or the rear diff mounted sensor has a wire break somewhere? Doesn't seem like there is anything else left to troubleshoot besides those two items.
Old Apr 10, 2026 | 08:34 PM
If your speedometer works properly, the rear sensor is fine. I don't know if there is a separate controller for abs on yours, it may just be controlled by the PCM......
Old Apr 10, 2026 | 08:41 PM
OregonApe's Avatar
OregonApe
Apparently I forgot to take photos, but this is what I pulled out. https://www.moparpartsgiant.com/part...5010917ab.html
Is that not the abs controller?
Old Apr 11, 2026 | 08:06 AM
That's what it says it is. I believe them.
Old Apr 11, 2026 | 08:16 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
While similar looking, that one shows it's for a Dodge Dakota pickup truck. If you're looking to replace the controller, definitely get the part number off of your's so you get the correct one.
Old Apr 12, 2026 | 04:53 PM
OregonApe's Avatar
OregonApe
Yup, I just was trying to show basically what I pulled out and google is incredibly bad about differentiating between b1500 vans and 1500 trucks. From what I can tell, they basically all used the same kelsey hayes controller with 2 different letters at the end of the part number.
Anyway, I just had an idea. An epiphany if you will. My parents have a '98 b3500, 5.9, rear wheel drive. I wonder if I stole their ABS controller whether it is the same as mine and whether that would tell me if mine is bad. God, it's such a pain in the rear to remove it though....
Then again, I've definitely had to hit the brakes in their van and the ABS didn't engage and I went screeching into an intersection (guy ran a red light in front of me). So I don't even know if their ABS is functional despite not having any lights on.
Old Apr 12, 2026 | 06:41 PM
OregonApe's Avatar
OregonApe
Update: it's my abs module.
Kind of anticlimactic. My module causes the exact same issues when connected to my parents' b3500. Their module works perfectly in my van.
Old Apr 13, 2026 | 05:20 AM
alloro's Avatar
alloro
At least you now know what the issue is. Check eBay or here https://www.car-part.com/ for a used one.
Old Apr 13, 2026 | 11:53 AM
OregonApe's Avatar
OregonApe
Thanks. Car-part actually shows more results than I was expecting. I wonder if there is any difference between years, V6, V8 5.2, V8 5.9, etc. Mine is a P52009460AK while my parents' is a P52009461AE from a '98 b3500 with the 5.9L. It didn't throw any codes in my 2000 b1500 5.2L but who knows. I didn't actually go out and stomp the brakes.
