Which Grill Guard
Which Grill Guard
I'm looking for a grill guard for my truck, but the ones I've seen down here use the tow hook location to mount the guard. Does anyone know of a grill guard that either repositions the hooks or does not cause you to loose them?
on
RE: Which Grill Guard
Every one I checked out needed the tow hooks removed to mount. However, my selection was limited as I wanted a grille guard with winch mount.
What I ended up doing was going all Warn, with the winch and Trans4mer grille, brush guard and winch mount. There are two holes on the bottom on either side of the winch mount that were the perfect distance apart to put a good size U-bolt through. I drilled them out a little bigger to accomodate a great big U-bolt and attached a 6.5 ton clevis to each. Kinda looks like the deal that all the Jeep guys with winches have set up. Works perfectly.
[IMG]local://upfiles/67238/E64CBF0F18F5430B95562CF0B8DC6D3E.jpg[/IMG]
