Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
raceing???
Old Jul 26, 2007 | 08:54 PM
Hemi_Delux's Avatar
Hemi_Delux
Default raceing???
how to get a good start?????
brake+gas at same time
or
put in N press gas then hit drive
or is there a better way im not sure how to do it
i would like to know. im ready to go up town and put the hemi to the test.
Old Jul 26, 2007 | 09:52 PM
playername's Avatar
playername
Default RE: raceing???
i wouldnt recommend going from N to D with the rpms anywhere above normal idle witht he brake on anything more increases your chances of tearing your trasmission appart.
Old Jul 27, 2007 | 01:39 AM
oefootball_70's Avatar
oefootball_70
Push the brake and the gas in, but only run it a thousand rpms above normal, then punch it as soon as you want to go releasing your brake.
Old Jul 27, 2007 | 08:11 AM
rtmorrisjr's Avatar
rtmorrisjr
ORIGINAL: oefootball_70
Agreed. thats the best way to get off the line the quickest.
Old Jul 29, 2007 | 09:20 AM
Raminator!!'s Avatar
Raminator!!
Foot breaking is best. Leave your vehicle in D, Press firmly with your left foot on the brake to hold the vehicle in place, and use your right foot to bring the RPM's up. This loads teh transmission and torque converter up so there is no instant jolt of power to anything.
It should be a smooth transition of power with the weight of the vehicle and your self being pushed back. Hence your forward momentum!!!
Not to sure where to put the RPM's at though. I usually have them up around 2000 - 2500 for a decent launch. But that is me.
Have fun!
Old Jul 29, 2007 | 04:56 PM
Drew's Avatar
Drew
for the hemi. . .2-2500rpm and just hold her down with the brake. Cummins, auto 1600-1800rpm and build about 10lbs of boost, stick, 3rd gear2000rpm and use clutch to built ~10lbs. when light goes dump brake and clutch at same time and mat throttle.
if 4x4 take off in 4x4, then aprox half way down track shift into 2wd. this will give you much better power to ground and keep the wheels from spinning too much off the line, after the 1/2 point shift into 2wd, chances of wheel slippage deminish after 3rd gear.
also, for the auto's, use the tow haul, it will lock the TC sooner
Old Jul 30, 2007 | 10:35 AM
Raminator!!
I really wouldnt take off with 4wd unless I had the power that would require me to do so. With my Ram 4x4, I launch in D, and keep my foot to the floor.....With Stock horse power, you shouldn't break loose unless there is water on the track or something.....or just have bad tires.
Old Jul 30, 2007 | 11:06 AM
Drew's Avatar
Drew
for me. . .anything over 15lbs of boost and I'm spinning all 4
Old Jul 30, 2007 | 11:08 PM
Raminator!!
ORIGINAL: Drew
Must be nice to have that kind of power!!
Old Jul 31, 2007 | 08:25 AM
Drew's Avatar
Drew
not when the roads are slick[:@]
