Tires
Tires
I Have just bought an '04 1500 QC long wheel base 4X4. It is all stock and in good condition. I am loking to put some larger than stock tires on and wanted to know how large of tire I can fit in the wheel well with out rubingbefor haveing to put a lift kit on.And any susgestions for a good AT tire and source.
Thanks
Rob
Thanks
Rob
RE: Tires
i have a 04 quad cab short bed with a set of285/70/17 Toyo Open Country AT's and have had them for almost a year and so far they have been a very good tire.
i cant even tell theyve worn down any! i highly recommend them and so far they have done very well in the snow and a lil bit of offroading!
RE: Tires
ORIGINAL: 2004hemi4x4
RE: Tires
pro comp xtreme at's... this pic they had about 52k on them... I'm up to about 55k now and they are still going strong. no balancing issues, good wear. the only problem I had on them was my toe was off causing cupping on the insides of the fronts. I fixed the toe at home and now they are evening out once again... nice even wear across the tread.
RE: Tires
im also looking for new tires, currently i have 31" on but im lookin to go ot 33 or 35 any recommendations on a good tire? mostly for street driving but off road and snow also. and of course the look is badass
Trending Topics
RE: Tires
welcome to DF... read the above posts... my pro comps rock and have very long tread life.
RE: Tires
ok so i found the tires i wanted going from 31" to 33" but i dont know if ill need to put a leveling or lift kit on. anyone know whats the max i can put on a 00 1500 before i need to raise it up
RE: Tires
you will be ok with a 33 or a 285/75/ r 16.... leveling it will just give you more room... i would reccomend it because it looks bettter and allows more room at a low cost..
