Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
TMR Explained...
Old Feb 16, 2004 | 10:30 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Default TMR Explained...
Posting This As A New Thread Since It's Sure To Be A Hot Topic...
Originally came from this post:
https://dodgeforum.com/tm.asp?m=16821
Okay are you HEMI guys ready... I'm about to give you a back door to what will make you truck faster... TMR is...
Long Story > > >
There are two speed sensors in the trans, one on the input shaft and one on the output shaft. The Transmission Control Module (TCM) monitors these speed sensors along with the throttle position sensor, accelerator position sensor, vehicle speed sensor and a few others. When the TCM sees wide open throttle and the truck is at a low speed, the TCM sends a "Torque Management Request" (TMR) signal to the PCM. The PCM sends back to the TCM a "Torque Management Requst Confirm" signal. This is when the PCM detunes our Hemi's. There is probably a profile under this TMR signal that retards timing, fuel etc. in relation to vehicle speed, throttle position, accelerator position etc.
Short Strory > > >
Pull the #7 (yellow with dark green stripe) wire on the 4th plug down on the ECM on the firewall. It makes the truck shift harder at WOT but you lose some traction control in the rain.
Those who have tried this have RAVED about the extra power in their Hemi!!
~Amanda
Old Feb 16, 2004 | 10:54 PM
Dodgegirl19
Lady Administrator
Default RE: TMR Explained...
One thing though... put it back to stock setup BEFORE taking it to the dealer for ANY reason.
~Amanda
Old Feb 16, 2004 | 11:24 PM
lawntycoon's Avatar
lawntycoon
will not work for the 04's right?
Old Feb 16, 2004 | 11:28 PM
Dodgegirl19
Lady Administrator
It will as far as I know on the Hemi Ram's... they didn't change from 03 to 04, did they?! LOL!
~Amanda
Old Feb 16, 2004 | 11:30 PM
lawntycoon's Avatar
lawntycoon
iam bouncing back nd forth on the other thread ........my info is on the other thread......thanks
Old Feb 16, 2004 | 11:46 PM
Dodgegirl19
Lady Administrator
https://dodgeforum.com/tm.asp?m=16913
Doesn't work on 04?!?! C'mon guys, I'm not the only one who can find info... lawntycoon is likely correct so make sure before doing this.
~Amanda
Old Feb 24, 2004 | 02:43 PM
Rambeast's Avatar
Rambeast
is it possable to do that to a 97 ram sport ?
Old Feb 24, 2004 | 03:55 PM
uhoh's Avatar
uhoh
It will NOT work on a 04. The 04's do not have seperate TCM's and PCM's.
Old Mar 8, 2006 | 10:28 PM
dannyac's Avatar
dannyac
Amanda, I have seen word of this in other Durango and Dakota forums. Will it work for any other engine? Are there ANY negative effects on the transmission?
Old Mar 9, 2006 | 11:22 AM
whoosh's Avatar
whoosh
What about 2006 1500's??
