Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
A weird shaking in my 99 ram
Old Feb 18, 2004 | 10:04 PM
moparmadness's Avatar
moparmadness
Default A weird shaking in my 99 ram
I was towing my horse trailer on the high way and all of a sudden my truck started to shake like the alignment was off. The check engine light come on for a while then I slowed down and the shaking went away and the ceck engine light. My truck has never done that before, the only problem that i've notice is that sometimes the truck will start to make a clicking or chatter noise when I accelerate up a hill. I took the truck to the machanic and he did a dianostic on it and nothing came up. Does anyone know what the problem could be
Thanks Frank
Old Feb 19, 2004 | 12:47 PM
steve05ram360's Avatar
steve05ram360
Default RE: A weird shaking in my 99 ram
Crank position sensor... would be my 1st guess. Couple of months back before I got my truck, I drove 1 with the same problem you describe. Not knowing what could be the problem I passed on it. Later I found posts indicating the crank position sensor could have been the problem. Located on the passenger side behind the head at the top of the block.
-steve
Old Feb 19, 2004 | 10:44 PM
moparmadness
what exactly does the crank position sensor do and how would it make my truck shake like that. Do you know where I can find a crank position sensor at. thank you for the help and i'll have to try that
Old Feb 20, 2004 | 01:42 PM
steve05ram360
It's behind the passenger side head at the top of the block (where the transmission bolts to the block). I would take it to a shop and have them check it out. They should be able to check it for you. Please keep us posted.
Steve
