Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Droppin' the rear of an '04Hemi
Old Feb 19, 2004 | 01:55 AM
goatslayerwp's Avatar
goatslayerwp
Default Droppin' the rear of an '04Hemi
I noticed the spring hangers are different on the 04 1500 4dr rams. I had a 98 half ton and you could lower the rear with shackles. I want to sit the rear down on my hemi, but not sure how to do it. I went to O'Riellys and bought Belltech drop shackles for a chevy and it worked great for squating the rear of my 98 since the leaf springs are the same width. What should I do about my Hemi, and keep in mind that the payment is huge on this thing, so I'd like cheapies, but anything ya got will help!
Old Feb 19, 2004 | 12:44 PM
steve05ram360's Avatar
steve05ram360
Default RE: Droppin' the rear of an '04Hemi
My suggestion would be to find the companies on the web with the lowering kits and see how they do it. Sometimes you can duplicate it cheeper. Case in point is my BMW and it's cold air intake kit... some companies want as much as $300 bucks for a decent kit, where as I found the heat shield for $85, intake tube for $40, and a K&N cone for $45... well below the $300 mark.
Hope this helps
Old Feb 19, 2004 | 01:52 PM
lawntycoon's Avatar
lawntycoon
you can have someone fabricate your shackles or purchase aftermarkets its cheap either way!! and I have a pic of mine on disk to show you if needed .....here is an example of somone that had some made or purchased and these look great ....these are not mine i used my factory ones....just an example . by removing the support leaf you will drop 5/8 inch and adding shorter shackles you will drop 2-1/8 in the real secret to the smoother ride in this type of drop is cutting 1/2 in off your rubber block with a metal saw blade. hack saw or whatever (over your axle) not more than that though.the only cost for this drop is what you spend on your shackles..cant get any cheaper than that and it is easy enough to return it to factory.....may have to buy the shackles from -parts yard or dealer or as a thought do that to begin with and have that part fabricated and keep your original shackles and put them away for later.......................
[IMG]local://upfiles/1277/Us539471418.jpg[/IMG]
[IMG]local://upfiles/1277/Rp423730451.jpg[/IMG]
[IMG]local://upfiles/1277/Kf142783057.jpg[/IMG]
Old Mar 16, 2004 | 11:49 PM
old38's Avatar
old38
Hi
I'm a newbie here so excuse my ignorance.
Lawntycoon, does it make any difference if the ram is a 4X4
Old Mar 17, 2004 | 12:56 AM
gcredneck02's Avatar
gcredneck02
i was just wondering, but why would u want to drop a four wheel drive?
gcredneck02
do you think on a '97 1500 and 2" drop in the front and a 3" drop in the back would look good? or would that not be low enough?
Old Mar 17, 2004 | 02:01 PM
lawntycoon's Avatar
lawntycoon
Old38...I wish I could honestly guide you on that 4x4 drop issue .....But its out of my league....im a 4x2 guy..sorry
Old May 15, 2005 | 12:26 PM
BMSMWC1's Avatar
BMSMWC1
wich leaf is the sopport leaf?
Old May 15, 2005 | 09:03 PM
guido7's Avatar
guido7
For what its worth, I had mine lowered, its a 4x2 but sent it to a shop that specialized in suspensions, leafs, etc...and they took them off and de-curved them...dont know the process but it worked, BUT you Have to change the rear shocks, I put on Monroe Air shocks
(adjustable), and it works great... looks at the pics on my Gallery and it will show it....Good luck.....GUIDO
[IMG]local://upfiles/13612/D1872E209C5E4C918B0897DA91A6A25A.jpg[/IMG]
[IMG]local://upfiles/13612/1AEC122CB244471CA22AC3584A3EC603.jpg[/IMG]
