Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Sponsored by:
Sponsored by: Mall of Georgia
Got A New Truck
Old 03-25-2004, 03:44 AM
HemiGuy25's Avatar
HemiGuy25
HemiGuy25 is offline
Default Got A New Truck
I SOLD MY 04 QC hEMI 4WD FOR A 04 SRT-10 RAM. i hope it was a good move. Any opinions? Any simple mods without touching the integrity of the v-10? tHANKS
Old 03-25-2004, 10:46 AM
Vader's Avatar
Vader
Vader is offline
Default RE: Got A New Truck
Wow, Enjoy your new ride. Can you post some pics for us. Did you take a financial beating trading in an 04 ??
Old 03-25-2004, 12:28 PM
gravymonkey's Avatar
gravymonkey
gravymonkey is offline
I don't know anything about mods for the SRT-10. I just know I want to see pictures of yours!!!
Enjoy the ride, I know I would!
-Erik
Old 03-25-2004, 01:16 PM
Dodgegirl19's Avatar
Dodgegirl19
Dodgegirl19 is offline
Lady Administrator
OMG OMG OMG OMG OMG I just saw one this past weekend at DCX HQ's... VERY VERY VERY COOL... I CANNOT wait to see pics from you!! YAY!! CONGRATS!!
~Amanda
Old 03-25-2004, 03:07 PM
HemiGuy25's Avatar
HemiGuy25
thanks everyone for your response pictures are on the way!
Old 03-25-2004, 03:13 PM
HemiGuy25's Avatar
HemiGuy25
Not to bad on the financial beating. They gave me 1000 less from what I owed with taxes included. The payment went up but I figured you only live once what the hay! The dealer was so happy cause it had the thunderroad package and its common down south were I bought the truck and not up here. He didn't have 1 on there lot and they are a pretty big dealership.
Old 03-25-2004, 03:15 PM
Dodgegirl19
Lady Administrator
How many miles did it have when you turned it in?
Don't you just LOVE the SRT-10?! I'm so excited for you!!
~Amanda
Old 03-25-2004, 03:36 PM
HemiGuy25's Avatar
HemiGuy25
when Ik turned the other truck in it only had 500 miles. I love both trucks sad to see the hemi go but also like the srt-10. I work from home so do not drive much. How come the Ford Lightning with 5.4 supercharged engine is rated the same 1/4 mile time 13.6 with around 350 hp and my truck is only 300 pounds more with 500 hp and runs the same time? Does anyone know?
Old 03-25-2004, 06:35 PM
bullitt1229's Avatar
bullitt1229
bullitt1229 is offline
ORIGINAL: HemiGuy25
I believe the Lightning has between 380-390 HP, but HP is nothing if you can't get it trasnferred to the ground. The Lightning may have a better suspension setup than the SRT-10. I'm not really sure though.
Old 03-25-2004, 08:42 PM
yawnshemi420's Avatar
yawnshemi420
yawnshemi420 is offline
I found this for your comparison
ENGINE
Configuration Longitudinally mounted, single overhead cam, 90-degree TritonTM V8, intercooled/supercharged, cast iron block, aluminum-alloy heads, forged steel crankshaft
Bore x Stroke 90mm x 105.6mm
Displacement 5,410cc/330cid
Compression ratio 8.4:1
Horsepower <b>360 hp @ 4,750 rpm </B>
Torque <B> 440 lb/ft @ 3,000 rpm <B>
Specific output 66.7 hp per liter
Redline 5,250 rpm (fuel shut-off occurs at 5,400 rpm)
Valvetrain Single overhead camshafts, chain drive, roller finger followers with hydraulic lash adjustment, beehive valve springs, two valves per cylinder
Intake valves 1 per cylinder, 44.5mm head diameter
Exhaust valves 1 per cylinder, 36mm head diameter
Fuel system Sequential electronic fuel injection, Premium calibration
Induction system Pressure-charged. Eaton Corporation Generation IV Roots-type supercharger, water-to-air intercooler in-vee
Supercharger 8.0 psi
Throttle body Dual-bore 57mm
Mass-air sensor 80mm diameter
Exhaust manifolds Cast iron tuned headers
Exhaust system Tuned dual exhaust, ceramic-coated dual exhaust tips
DRIVETRAIN
Transmission Four-speed automatic (4R100)
Final drive 3.55:1
Rear axle 9.75 in. limited slip
Gear Ratio Maximum Speed In Gear
1st 2.71 45 mph
(72 kph)
2nd 1.53 80 mph (129)
3rd 1.00 125 mph (201)
4th 0.71 140 mph (225)
Reverse 2.176
<b>
SUSPENSION
Front Twin short- and long-arm type, coil springs, tubular gas-charged shock absorbers, 31mm solid stabilizer bar
Rear Solid axle, staggered gas-charged shock absorbers, five-leaf springs, 23mm solid stabilizer bar </b>
STEERING
Type Recirculating ball, power assist
Gear ratio 14.0:1
Turns, lock to lock 3.3
Turning diameter 44.3 ft
BRAKES
Front 12.1 in. (308mm) vented disc, twin-piston caliper
Rear 13.1 in. (334mm) vented disc, single-piston caliper
ABS Four-wheel ABS, three-sensor system
WHEELS & TIRES
Wheels 18 x 9.5 in., five-spoke cast aluminum-alloy, painted surface,locking lug nuts
Tires Goodyearâ„¢ Eagle F1-GS, 295/45ZR-18, unidirectional tread
LIGHTNING INCLUDES
Supplemental restraint system:
Driver and passenger airbags. Always wear your safety belt and deactivate passenger airbag when using a rear-facing infant safety seat
Passive Anti-Theft System (SecuriLockTM)
Anti-lock brake system (ABS)
SVT suspension tuning, with lowered ride height
40/60 bench seating. Six-way power for driver's seat, with cloth/leather trim and specially designed lateral bolstering
Premium electronic AM/FM stereo with cassette
Power Equipment Group: Dual electric remote control mirrors, power side windows, power door locks
Leather-wrapped four-spoke tilt steering wheel, thicker section-width rim
Super Engine Cooling and Auxiliary Transmission Cooler packages
Engine oil cooler Trailer tow package
Air-conditioning (manual control)
Electro-luminescent SVT white-faced gauge pack, including supercharger boost gauge
Sliding rear window
Speed control
Front floor mats
SVT and Lightning badging
Remote keyless illuminated entry
Quick Reply: Got A New Truck
