Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Remove Door Panel
Old Mar 26, 2004 | 03:35 PM
henry1088's Avatar
henry1088
Default Remove Door Panel
I'm looking at putting some tint on the side windows of my 03 Reg cab because I'm tired of getting sun sick. My question is how do I remove the panels with out breaking anything. Its got the power mirrors, locks and windows as well.
Old Mar 26, 2004 | 05:31 PM
yawnshemi420's Avatar
yawnshemi420
Default RE: Remove Door Panel
I would like to know how as well, I need to install Dynamat on the door metal.
Old Mar 26, 2004 | 06:05 PM
dodgefreak's Avatar
dodgefreak
not sure on the 03's but the 2nd gen just had two screws and a bunch of clips.
As for the tint...on the 3rd gens there is a wheel in the door that rubs on the glass when its being put up or down. You have to cover that with felt or else it will scratch the heck out of your tint!!
Old Mar 26, 2004 | 06:44 PM
yawnshemi420
I don't think its the same on the 04's. I've had my tint for four months now and they are still perfect.
Old Mar 26, 2004 | 07:03 PM
dodgefreak's Avatar
dodgefreak
YEAH, i KNOW IT WAS THE 02' AND 03'S THAT HAD THE PROBLEM.
opps caps lock lol
Old Mar 26, 2004 | 07:06 PM
yawnshemi420
OOPS my bad he was talking about an '03. I thought I read he had an '04.
my bizzle
Old Mar 26, 2004 | 07:16 PM
mississippi's Avatar
mississippi
On the 02-04 model trucks, all you have to do is take 2 screws out of the bottom of the panel, 1screw from behind the door handle, 1 screw from the top where the infinity badge is or goes, and remove the door handle. I believe the door handle requires a 10 or 12 mm socket. After all that is removed lift up on the panel and it should come right off. After you have the panel off, remove the plugs for the door lock and power window switch and you can take the panel away. Hope this info helps.
Old Mar 26, 2004 | 07:29 PM
dodgefreak's Avatar
dodgefreak
ORIGINAL: mississippi
must everything go to friggin metric!!! gone are the days of ONE set of sockets!!!
Old Mar 26, 2004 | 07:33 PM
mississippi
ha ha ha ha .... true.....so true!!! [sm=smiley36.gif]
Old Mar 29, 2004 | 12:16 PM
Klute's Avatar
Klute
The front door has a screw in the sail and two screws in the bottom.
The screw for the door handle is a torx size 30.
My 02 did not have any clips, more like hooks.
The back doors just have the 2 crews in the bottom and the door handle screw.
Remove screws lift panel up and out.
