Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Brake Pads Causing Squeak
Old May 4, 2004 | 02:05 PM
cubfan23's Avatar
cubfan23
Default Brake Pads Causing Squeak
I am hearing a squeak while driving and the squeaking stops when I press on the brakes. Does that mean that my brake pads are getting worn?
I took it into a local auto shop and had them do a brake check...they said there weren't any problems. So, now I'm at a loss for what might be causing the squeaking noise.
Any thoughts?
Old May 4, 2004 | 03:24 PM
twistx's Avatar
twistx
Default RE: Brake Pads Causing Squeak
From what I'm told there are a few possibilities. Standard american rotors are made without any nickle in them so they rust real quick around moisture. That buildup could cause squeaking (or grinding if it gets bad) sounds. Break dust could be a cause... I dunno where it comes from (could be anywhere i guess). Lastly, new break pads can do it to, but it sounds like you've had these for a while.
I had the same problem on a previous car of mine. My uncle (who is a mechanic) put some stuff on the break pads to make it quick squeaking.
Old May 4, 2004 | 09:55 PM
cubfan23's Avatar
cubfan23
Thanks twistx! I'll see if I can track down what's causing this and get rid of it...it's driving me crazy! [>:]
Old May 5, 2004 | 01:10 AM
356MAGNUM's Avatar
356MAGNUM
You can go to any autoparts store and get "squeak stop". Its a waterproof graphite (i think) that goes inbeween the break pad back plate and the caliper. Usally about $2
Old May 6, 2004 | 07:27 PM
Migi's Avatar
Migi
I am having the same problem. For me it just comes from the right front wheel. Everywhere I take it thinks that I am crazy because they can't hear it. If you fix the problem, please pass on the info. Thanx.
