just a quick question
can i fit a 36 tire on a 97 ram sport with out a lift ? i searched the fourm but didn't find anything . reason i'm asking is because i can get a reall good deal on them from my friend.
I doubt it bro... I ran 35" on a Stock no lift 97 Ram 2500 and I had some serious rubbing. This is an HD 2500 with the 3" rear leafs.. I finally broke down and picked up a set of Superlift 2.5" front lift coils only set you back 200 bones. No more rubbing now!!!
You can pick up a set of Coil Spring Spacers off Ebay for under 100 bucks. That will take care of the front. This will net you a couple inches, If you need more you will need to go with springs.. Superlift has nice Springs, but if you go higher than 2.5 inches you'll want to use the "Kit" as it will come with brackets longer shocks etc.
