OFF Road tires
B][GT are you measuring your tires from the ground up or across the tire from front to back. I have 20's on mine and they measure 33 front to back if I check them top to bottom then I get 32 due to the weight of the truck.I was thinking of getting the new BF's 315 which are 35", only 1" more on the radius..My tire guy thinks they will work with out a lift but im not to sure.
ANIMAL
ANIMAL
I had measured anything, just doing the math on the size numbers. I can see the 315's working on a 3/4ton .. but i think theyd rub on the 1/2's. We have a small advantage over the guys with 17's cuz we dont HAAAAAaaaave to change our rims when we lift our trucks, the stock 17's dont have enuff backspacing to clear most lift kits new tie-rod ends. Dunno bout you guys but i like my 20's, and will be keepign htem when i lift mine.
Just a offnote Rob, if he's looking for mud terrains, or evan all terains.. im gonna guess he's not looking to corner dive
But i didnt mind my 35's BF mud terrain's on my old ford, and still took most corners at 170-180km. (sorry for the km/h
Troy
)Troy
