Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Underdrive Pulley
Old Jun 9, 2004 | 09:30 PM
Mikeg1005's Avatar
Mikeg1005
Default Underdrive Pulley
Anyone ever put on or think about putting on underdrive pulleys on their truck? Did you get much power back from them, are they worth it? Just trying to see what all your opinions are on stuff.
Old Jun 9, 2004 | 10:14 PM
Racer Rob's Avatar
Racer Rob
Default RE: Underdrive Pulley
I am interested in the info as well.
Old Jun 10, 2004 | 01:12 AM
JCswm's Avatar
JCswm
On a STOCK engine they work great!!!!
Add ANY electrical draw (lights, Stereo or a trailer)and you'll have problems at night with the AC on unless you get a bigger Alt. pully!!!!!!
Old Jun 11, 2004 | 06:25 AM
356MAGNUM's Avatar
356MAGNUM
A way around that is if you are doing the stereo bit, is to add a "cap". It is usually a 1 farad capacitor that runs around $100. Any stereo shop has them, heck even walmart has them. What a cap does is stores a small amount of voltage for peaks that hit hte electrical system(the boom booms). For draws that are constant, they do little, if no help. They are "transient" devices.
Old Jun 15, 2004 | 09:19 PM
glock45's Avatar
glock45
I notice at night that my interior lights pulsate a bit - I figure either my alternator is undersized (as far as I know its stock) or its on its way out?
The lights dont go totally out and you have to look at them to notice but after reading this post I would assume I would have a real issue if I pursued the under pulley option.
Is the under pulley system really worth the $200.00 + dollars?
Any thoughts are appreciated.
Old Jun 16, 2004 | 05:02 AM
356MAGNUM's Avatar
356MAGNUM
Do you have any extra lights or stereo equipment added? You should be able to take it to a parts place like Auto Zone and get a free alternator check. If it is a steady pulsating, I would say that the alternator is having a lil prob.
Old Jun 16, 2004 | 05:42 AM
71GTX's Avatar
71GTX
I would tell anyone with the 5.9 to get the pulleys. I had them on my first 96 with headers, MPM Mperformance Comp., air ram hood with KnN. They did make it quicker once the RPM's hit above 2500. On idle the voltage would go down to around 10 or so. Had to rev up to 1800 or so to launch hard as the lower voltage would bog it down. Used to keep up with stock 5.0 mustangs with these mods.
Old Jun 16, 2004 | 01:40 PM
B12Teuton's Avatar
B12Teuton
They are great for a manual tranny where you keep the rpm spinning a bit higher than an automatic anyway. The only time you should have a voltage problem is at idle. Anything above idle and the belt speeds everything up enough that you shouldn't notice any difference IMO.
Old Jun 16, 2004 | 10:31 PM
glock45's Avatar
glock45
No extra elec equipment, yet, the only thing I have replaced was the stock radio - I put in a Kenwood KDC-9011.
I am planning on adding some lights to the front eventually.
I am gonna be pissed if I have to buy an alternator- its only got 30,000 on it!
Old Jul 12, 2004 | 10:44 PM
lawntycoon's Avatar
lawntycoon
Who sells them?
