Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
2004 engine coolant resavoir leak
Old Jul 20, 2004 | 10:24 PM
mopowrmike's Avatar
mopowrmike
Default 2004 engine coolant resavoir leak
the dealer replaced my 2004 hemi coolant resavoir to a 2005 resavoir , hopefully to stop the spill over. it doesnt leak as much but it still is leaking, anybody have any ideas to what it might be? it wasnt till the third atempt to fix this problem , what can i do next?
Old Jul 21, 2004 | 01:34 AM
mazz's Avatar
mazz
Default RE: 2004 engine coolant resavoir leak
If it's leaking, either there's too much coolant in the system, or something is causing the coolant to overheat enough to cause expansion. Sounds like all the dealer did was put a bandaid on the problem. Did they check to make sure the thermostat was opening at the proper temperature? I think a coolant flush might be necessary. It's possible there's some small obstruction in the system.
Old Jul 21, 2004 | 11:38 AM
mopowrmike's Avatar
mopowrmike
the coolant is right where it is supposed to be. the truck did heat up passed 220 once took it to dealer they ran the engine for a time a/c on and put it in gear, nothing happend. like i said when i drive for a good while and then check the resavoir there is always a wet spot. sometimes alot sometimes a little bit.
Old Jul 21, 2004 | 01:09 PM
sean283's Avatar
sean283
ORIGINAL: mopowrmike
Nope... But if you don't mind - let me know if it helps.
Mine does that too. The level looks good but after a week of driving you can see where it has boiled over out of the expansion bottle down the fan shroud. I wipe it off and a few days later it's back[:@]
Also, The top seam of the bottle has red coolant residue all over it. Bad bottle?
Old Jul 21, 2004 | 01:26 PM
1EvilBee's Avatar
1EvilBee
Mine does the same thing...and still does even AFTER they replaced it. I'm thinking to tell them to switch it to the 03 coolant system, where the radiator cap is on TOP Of the resivior tank
Old Jul 21, 2004 | 06:21 PM
moparturd's Avatar
moparturd
I have that residue as well, but the level seems good.
Old Jul 23, 2004 | 08:45 PM
mopowrmike's Avatar
mopowrmike
talked to the dealer and they told me they will need to run a compression test to see if i have a bad head gasket , this will happen on monday i will let you guys know what the outcome is!
Old Jul 24, 2004 | 11:02 AM
moparturd's Avatar
moparturd
Good luck with that. I hope you don't have a hd gasket problem. Have you noticed any excessive white smoke/steam from the exhaust at start-up?
Old Jul 25, 2004 | 04:43 AM
rambob's Avatar
rambob
I've got a 04 1500 reg cab 2wd 4.7 auto and mine does it too. I had it a Rockwall Dodge and they replaced the coolant tank and radiator cap and it still does it. It never overheats or anything, it just puddles up on top of the tank.
The service manager said he was going to call Dodge and to bring it back when he could have it all day to do some tests but I don't think it is going to do any good.
