Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
front lift for 04' 1500 Quad Cab
Old Jul 29, 2004 | 02:24 PM
cwoods's Avatar
cwoods
Default front lift for 04' 1500 Quad Cab
I would like to lift my front by adjusting the torsin bar, to level out my truck. I heard a 1 1/4" is a safe number.
Are there any issues with warranty??
How do I measure the 1 1/4", threads or truck height??
Do I have to have my truck off the ground??
Thanks! [8D]
Old Aug 1, 2004 | 05:06 AM
sudadog's Avatar
sudadog
Default RE: front lift for 04' 1500 Quad Cab
All you need to do is jack up the front end so your wheels are off the ground, then slide under the cab and tighten the adjustment bolts at the end of the torsion bar. Four turns clockwise will give you a little over an inch of lift. Make sure you turn both bolts the same number of turns.
This will put some extra wear on your tires, so make sure you rotate them frequently. Also, I have been told that if you ever get an alignment, they will probably mess with your adjustments...
