Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
2004 - 3/4 ton Power Steering Vibration moving or not moving
Old Aug 25, 2004 | 04:36 PM
hemixav's Avatar
hemixav
Default 2004 - 3/4 ton Power Steering Vibration moving or not moving
Hi !
I would like to know if anybody had the same problem before:
- When driven for the first time in the day, I can feel a VIBRATION THROUGH THE STEERING WHEEL as I turn the wheels to the left (doesn't look like it does it to the right).
- The truck can be MOVING OR NOT MOVING it does not make a difference.
- It looks like it's coming from the power steering system but does not make it after this ... till the next cold start.
- It only makes it on a "section" of the turning.
- It started doing this after approximately 6 months.
- I cannot see any trace of leaks anywhere.
Any idea ?
Thank you.
Xman
Old Aug 25, 2004 | 05:20 PM
hemixav's Avatar
hemixav
Default RE: 2004 - 3/4 ton Power Steering Vibration moving or not moving
Also,
I just looked at the power steering reservoir and something looks weird to me: the opening in the reservoir is approx. 1.5" dia. and on the top of the stick, there is a O-ring that is approx 0.5" dia. O-rings are supposed to be there to seal something, but I did not see anything that restricted the reservoir opening dia from 1.5" to .5"... so it does not touch anything ...
