Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Anti-Spin
Old Aug 26, 2004 | 01:20 AM
yawgom's Avatar
yawgom
Default Anti-Spin
How does it work the anti-spin axle? It is a ccomputer controled system or what it is exactly? I ordered it, the truck fells very controlled when I take hard turns, not like others 4x2. And lastly going uphill in slippery conditions, the anti-spin wold give me some benefits or not?
Old Aug 26, 2004 | 05:04 AM
yawgom's Avatar
yawgom
Default RE: Anti-Spin
Where are the tech guys?? Anyone?
Old Aug 26, 2004 | 05:06 AM
AkDanoM's Avatar
AkDanoM
maybe take this post to general Tech forum ... ???
might get a faster response time in there
Old Aug 26, 2004 | 10:46 PM
356MAGNUM's Avatar
356MAGNUM
http://auto.howstuffworks.com/differential8.htm Explains limited-slip. All i did was a google search on "limited-slip rear"
Old Aug 27, 2004 | 08:15 AM
yawgom's Avatar
yawgom
Im not really sure that limited slip is EXACTLY the same thing that anti-spin. Are you??
I had the idea that maybe they make the same function, but in a different way. I've seen another threads where someone says that antispin = limited slip and a lock, and then someone says that they are different things, the fact is that I dont understand who is correct??
Old Aug 27, 2004 | 12:38 PM
94ram4x4 5.9's Avatar
94ram4x4 5.9
limited slip is a very good all around rear-end. If you ever travel off-road and you want to optimize your traction when you are off-road, the limited-slip posi would be the way to go. Limited-slip provides traction to one wheel when traction is lost on either wheel, so say you floored it around a corner, usually the outside tire would not have any power and the inside tire would spin(peel-out) whatever you want to refer to it as. This prevents the vehicle from losing control and fishtailing or spinning out like what would happen in a posi-trac equipped vehicle. It really depends on your use whether or not you would benefit from the limited-slip. Hope I could help explain it a little better, I did notice you had a reply that directed you to Google.
