Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Annoying Light Problem
Old Aug 27, 2004 | 12:08 AM
BQHurricane's Avatar
BQHurricane
Default Annoying Light Problem
Ok, so my 98 Dodge Ram started leaving its parking lights (possibly brake lights) on when the truck is off. This started when the battery was unhooked and reattached (resetting the alarm). I disengaged the alarm and the lights stay on. I even pulled the parking lights fuse and the lights stay on. The only way I can get them to stay off is if I unhook the battery. What could be possible causes of this, and what are possible fixes? Thanks a bunch.
Old Aug 27, 2004 | 01:17 AM
mazz's Avatar
mazz
Default RE: Annoying Light Problem
First, is it the parking lights or the brake lights? Front and rear or just rear lights? If it's just the rearlights, and you pulled the fuse for the parking lights, that would explain why the rears remained on. If it is just the rear tails, my guess is it's the brake lights and the brake switch (located near the brake pedal) has gone bad, keeping power "on" to the brake lights all the time. Hey, I could be all wet here, it's just a thought.
Old Aug 27, 2004 | 12:40 PM
94ram4x4 5.9's Avatar
94ram4x4 5.9
check your relays under the hood also, if you pull the right fuse of relay you will not get any power to the lights
Old Aug 27, 2004 | 06:35 PM
BQHurricane
Well, the yellow lights on the front stayed on, as did the white lights near my rear license plate, and (I think) my rear brake lights were on faintly. In any case, this had happened before and was fixed by disabling my alarm system. In this case, I unhooked the battery for half an hour and it stopped for now and hasn't happened again. Does Dodge ship their trucks with retarded alarm systems or something?
