Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
Sprinter p0715 (trans Speed Sensor) T-shooting?
Old Nov 1, 2014 | 05:26 PM
middstate's Avatar
middstate
I have a 2005 dodge sprinter with a po 715 code. Could I get a pdf file on on checking this circuit. e mail is middstatetowing@yahoo.com
Old Nov 2, 2014 | 09:16 AM
morris841's Avatar
morris841
Default Sprinter p0715 (trans Speed Sensor) T-shooting
My Van is still on jack stands the dealer wants a $$$$$$ Please send pdf so can recheck.
----------STILL WAITING ON FIRST ONE ASK FOR-----------------
-------------PLEASE NEED HELP-------------------
Old*08-09-2013, 12:01 PM
morris841's Avatar morris841* morris841 is offline
Default*code P0715 need PDF
* _____ *
Yes code P0715 need PDF to check wiring Replaced*conductor*plate. Still code and in limp mode.*
Once changed right part will unit clear limp mode or will I need to take to dealer?
Old Sep 28, 2016 | 09:30 AM
KingKoupe's Avatar
KingKoupe
Originally Posted by master tech
Yes i have replace them on the dodge charger with the same transmission. And it did fix the problem. But you could also have a wiring problem too. If you need the pdf file for testing, let me know.
Hello, im having the same fault code with 06 sprinter, can you kindly send me the pdf file as well, Kingkoupe1@yahoo.com
Thanks in Advance
Old May 18, 2017 | 04:23 PM
jAmes hOpkins's Avatar
jAmes hOpkins
New Member
Default Sprinter P0715 (trans Speed Sensor) T-shooting?
Sprinter 2006 2500 code P0715 need PDF to check wiring
Replaced 13 pin connector and conductor plate.
Cleared OBD2 code and tranny code with Autel 802 code frequently resets and goes into limp mode.
Please send wiring troubleshooting PDF to hoppyjunk3@gmail.com
Old May 24, 2017 | 03:08 AM
hoppyski's Avatar
hoppyski
Default Sprinter T1N 2006 2500 P0715 Troubleshooting PDF
Dodge Sprinter T1N 2006 2500 140" wb cargo 222k miles has recurring P0715 and Limp Home Mode 2nd and reverse only.
I replaced leaking 13 pin Connector, Conductor Plate, 8 quarts Shell ATF134, and filter. Old fluid was brown with some grey sediment but no significant metal particles in filter.
Checked TCM connectors for wicked tranny fluid, cleaned a few damp spots with CRC contact cleaner.
Cleared transmission and ECU codes with Autel MD802 several times but codes for speed sensor mismatch return an a few hours or a few days and reset P0715 and LHM. Currently that is the only ODB2 code.
About 30% of the times I try to read the transmission codes the Autel MD802 gives me an "unable to communicate with requested module" This only occurs with ECU and other modules 2% of the time. I suspect a loose wire or short in tranny to TCM harness but have not found anything.
Need advice on what to try next and trouble shooting procedure.
Also need advise on removing a sheared Torque Converter drain plug.
Old May 26, 2017 | 10:05 AM
kawracer's Avatar
kawracer
Hello, im having the same fault code with 05 sprinter, can you kindly send me the pdf file as well, kawracer@yahoo.com
Thank you
Old May 26, 2017 | 10:13 AM
kawracer's Avatar
kawracer
Thank you.
Old Jun 7, 2017 | 11:12 AM
kawracer's Avatar
kawracer
Hello, im having the p0715 fault code with 05 sprinter, can you kindly send me the pdf file as well, kawracer@yahoo.com
Thanks in Advance
Old Jul 16, 2018 | 01:58 PM
Rachelle's Avatar
Rachelle
New Member
Default Please email PDF
Hi, my boyfriends 2006 Sprinter is giving us this same code (P0715). Can you please email me the PDF? Chellerowe3@gmail.com
Thanks,
Rachelle
Old Dec 17, 2020 | 10:50 PM
Michel Palmeiro's Avatar
Michel Palmeiro
Default michel790123@gmail.com
Would you help me with the pdf please I have the same problem thank you very much
