Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
Sprinter p0715 (trans Speed Sensor) T-shooting?
Old Aug 29, 2021 | 03:32 AM
  #21
dodgerfanjon's Avatar
dodgerfanjon
Default P0715 Testing Procedure PDF Yes Please
Originally Posted by master tech
Yes i have replace them on the dodge charger with the same transmission. And it did fix the problem. But you could also have a wiring problem too. If you need the pdf file for testing, let me know.
Thank you so much would love some direction. send to jrector@ccsolar.com
Old Sep 12, 2021 | 04:47 PM
  #22
monstercreech's Avatar
monstercreech
Default P0715 2008 Dodge Sprinter code.
Sure I can, Send me your email address by a pm and I'll send it.
Will not switch out of 2nd gear. Do you think that PDF file would help? P0715
Thanks
Old Oct 22, 2021 | 01:23 AM
  #23
lidosurf's Avatar
lidosurf
Default 2008 dodge sprinter in limp mode po715 code
Hi my 2008 dodge sprinter diesel 2500 is stuck in limp mode PO 715 code. Can you please send pdf to my email (lidosurf at yahoo.com) thanks
