Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
hesitation and stuttering
Old Jul 13, 2007 | 08:54 PM
gwilkrrs's Avatar
gwilkrrs
Default hesitation and stuttering
92 rt dohc 150k
new tune up plugs wires before i owned car. hesitation while rolling into throttle with poping comming form exhaust.
ignition timing? how what to check?
friend foolowing car said it smelled bad giong down road and it might be too lean?
Old Jul 15, 2007 | 07:35 PM
gwilkrrs's Avatar
gwilkrrs
Default RE: hesitation and stuttering
seems to stutter bad between 1000 to 3000rpm.
ecm and edc were replaced 3 weeks ago as well.
when coming to a stop i put ther car in Nuetral and the tach junps from 1500 to 27oorpm not a steady idle. what is this?????
Old Jul 15, 2007 | 08:16 PM
yevgenievich's Avatar
yevgenievich
not sure if this cars have them but could be something like tpi sensor or idle air control. it might be strugling to get the fuel flowing for some reason. was it doing it before computer replacement
Old Jul 16, 2007 | 06:41 PM
gwilkrrs's Avatar
gwilkrrs
yes it was, the ecmu was supposewd to fix it.
what doyuo plug into these cars to tell whats wrong and how much are they?
Old Jul 16, 2007 | 07:58 PM
thestealth's Avatar
thestealth
http://www.stealth316.com/2-diagcodes91-93.htm
There is the procedure for checking trouble codes on an ODB1 car.
Your car is a first generation isn't it??
Old Jul 17, 2007 | 06:24 PM
gwilkrrs's Avatar
gwilkrrs
yes its a 92. let me check your link to see if i can scan the car
Old Jul 17, 2007 | 09:15 PM
thestealth's Avatar
thestealth
Just follow the procedure and you should have no problems.
Just for grins, try unhooking the wiring harness to your ECS computer and see in the hesitation goes away.
Old Jul 18, 2007 | 08:42 PM
gwilkrrs's Avatar
gwilkrrs
its already unhookrd
Old Jul 18, 2007 | 08:53 PM
yevgenievich
Could it be avacuum leak?
