Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
FLASHING LIGHTS AND WONT START
Old Aug 25, 2007 | 07:06 PM
stealth888's Avatar
stealth888
Default FLASHING LIGHTS AND WONT START
My car was dead the other day, soi charged it. When i went to start it it took the charge because the lights and everything worked, but it wouldnt turn over. All the lights and dash lights in the car start to flash when i open the door or turn the key on. I was just wondering if anyone knew the problem or if the computer needed to be reset? If so, where is the computer located?
thanks
Old Aug 26, 2007 | 01:17 PM
yevgenievich's Avatar
yevgenievich
Default RE: FLASHING LIGHTS AND WONT START
to reset the computer you can undo the negetive cable from battery for 5 minutes, and as far as engine not turning over, possible that it is the starter, altrough i had same problem once and the next day it started just fine and never happened again. Maybe computer is going crazy?check capacitors
Old Aug 26, 2007 | 09:57 PM
workinprogress's Avatar
workinprogress
sounds like you charged the battery backwards....... i know i sounds stupid but it does happen......just ask my ex wife and te poor defensless ford probe she killed......check your polarity with a multimeeter........ if this is the case.... you just toasted an altinator....
Old Aug 27, 2007 | 10:18 AM
thestealth's Avatar
thestealth
Are the battery terminals corroded/loose? Will the car jumpstart?
Take the battery to an autoparts store for testing...
Old Aug 28, 2007 | 05:10 PM
stealth888's Avatar
stealth888
i tried resetting the computer and that didnt work...one of the cables was kinda loose but i got a new clamp and its still a little loose so i dont know what the problem is.
Old Aug 28, 2007 | 05:21 PM
thestealth's Avatar
thestealth
A loose/corroded battery cable will give these cars fits. Use a knife, or hacksaw blade to trim a little of the lead where it pinches together. That will let you clamp the terminal down a little tighter. Use a wire brush (or battery terminal cleaner if you have one) and clean everything really well and put it back together. Jump start the car if need be, then take the car and tools to the nearest parts store and have them test your battery. Take money so you can buy a new battery. Problem solved. (hopefully)
Old Aug 28, 2007 | 05:24 PM
stealth888's Avatar
stealth888
aright ill give er a try n hopefully something works here...thanks
Old Aug 29, 2007 | 11:02 AM
xcrashx's Avatar
xcrashx
You can also use baking soda and water to clean up any corrosion. Also make sure that your battery isn't grounding out by making contact with something it shouldn't be. Could cause that.
MB
Old Aug 29, 2007 | 03:48 PM
95Stealthguy's Avatar
95Stealthguy
Stealth888,
I have a 95 Stealth... Do you have a Viper Alarm system in yours? I know that is what it was on mine... same problem it sounds like. Look under the drivers side dash and see if you see 2 small buttons. They may be well concealed. 1 is the Valet switch and 1 is the disarm button...
Hope this helps..
Tony
