Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
DOHC 24 Valve
Old Jan 29, 2008 | 11:28 AM
Ezbay3330's Avatar
Ezbay3330
Default DOHC 24 Valve
I bought a 94 Dodge stealth (supposed to be all origional) and on the side windows it is marked as a DOHC 24 valve motor. I had the motor rebuilt and it is aSOHC. The odd thing is my mechanic insists that the motor has never been apart and the stamped number on the block matches the tag on the firewall? How can this be?
Old Jan 29, 2008 | 11:43 AM
thestealth's Avatar
thestealth
Default RE: DOHC 24 Valve
Take a picture of your engine.
Old Jan 29, 2008 | 12:33 PM
Ezbay3330's Avatar
Ezbay3330
I am at work right now but it looks identical to this 94..
Old Jan 29, 2008 | 01:11 PM
jookie7705's Avatar
jookie7705
Well if yours does look like that, then yes, it is a SOHC. The valve cover and intake plenum are dead give aways. When you get home and look at your engine and they look different than the pic, you have a DOHC. If it does indeed say DOHC on the rear quarter windows, a previous owner may have simply replaced them at one time.
Old Jan 29, 2008 | 03:06 PM
Ezbay3330's Avatar
Ezbay3330
Well that stinks. My car is near mint and this will take from the value, right? Will this also give me less HP?
Old Jan 29, 2008 | 08:46 PM
jookie7705's Avatar
jookie7705
As far as the value goes, maybe. If the windows were damaged and replaced it's possible. Another possibility is for some unknown reason, the DOHC stickers were put on the windows. Either way, yes that gives you less HP. The NA DOHC is rated at 222HP while the SOHC at 162HP.
Old Feb 6, 2008 | 12:15 AM
michap62's Avatar
michap62
Hey, my name is mike! and im new to this forum thing! ( starting to like it ) .... but i have a question! ... i just bought a 1992 dodge stealth a couple days ago ... this stealth is and ES .... its the orignal motor ... so its a DOHC right? .... the ES R/T and twin turbo were all DOHC's and then just the base model stealth was SOHC right!?!
Old Feb 6, 2008 | 11:37 PM
EvilZombieZ's Avatar
EvilZombieZ
ORIGINAL: michap62
Correct.
Old Feb 7, 2008 | 07:48 AM
jookie7705's Avatar
jookie7705
Yes, that's correct. Only the base model Stealth is SOHC, a base 3000GT is DOHC. It was a Dodge thing, wanting to keep the price down for that model.
