Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Hi I just bought a 92 stealth es and I have a few problems and questions
Old Aug 29, 2011 | 06:50 PM
Girly TT's Avatar
Girly TT
You will need the axles from the 94 in order for that transmission to work in your car.
Old Mar 17, 2012 | 08:33 PM
DrPain's Avatar
DrPain
I also have a 92 dodge stealth ES and it has battery drain issues. Checking with a voltometer and the number of amps (its drawing 5.3 amps) while the car is off. I have unplugged all the fuses and relays i can find so far and no luck in reducing the amps. I also unplugged the alternator and starter (disconnecting starter dropped 0.9 amps), but again no luck. Also disconnected circuits and light bulbs for trunk lights, door lights, hood lights. Still no luck. Any ideas on what is drawing the battery down?
Old Mar 21, 2012 | 03:11 PM
Girly TT's Avatar
Girly TT
have you tried getting your alternator tested?
Old Mar 23, 2012 | 08:29 PM
DrPain's Avatar
DrPain
No, not yet, but I don't think that's really the problem since the car seems to run just fine when the battery is charged up.
Old Mar 24, 2012 | 02:56 PM
Girly TT's Avatar
Girly TT
get your alternator tested.
Old Mar 24, 2012 | 04:36 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
You can put a screw driver (or another metal object) next to the alternator and see if it pulls the screwdriver to itself. This works on older cars so I owuld imagine it will work on newer cars.
FF
Old Apr 5, 2012 | 08:06 AM
Maelthras's Avatar
Maelthras
I hope you got it all fixed and figured out.
Old Oct 9, 2012 | 04:25 PM
skelit0re's Avatar
skelit0re
Default 92 stealth trans limp mode
actually it was the TCU. I got a new one and everything was perfect for about 8 months. high rpms between 2nd and third after a while, then back into limp mode. I got it working again, i KNEW it was the caps, and all of a sudden it drained the battery overnight and now i replaced the caps but still nothing. I am about done with this piece of junk car. I will never buy anything from mitsubishi or dodge ever again. what crappy workmanship!
Old Oct 10, 2012 | 07:06 AM
toddrs93's Avatar
toddrs93
Are you talking caps in the Ecu or tcu? And who did them? Most people fail to do them correctly. We frequently have to go back and fix shoddy cap jobs other people did not do correctly
