Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
92 dodge stealth has NO spark... Help Please!!
Old 04-13-2012, 07:19 PM
Jerry Oliver's Avatar
Jerry Oliver
Jerry Oliver is offline
Default 92 dodge stealth has NO spark... Help Please!!
My 92 dodge stealth non turbo was running great but needed a new battery so I replaced the old one.. The car was doing fine till I got home & went to go to the store an hour later & the car would crank but wouldn't start. So I checked it to see if it was getting fuel & it was So then I checked to see if it was getting spark & it wasn't. So I went & bought new coil, ignition control module, Cap & rotor button.. And still no spark.. so then I made a code reader with a 470 ohm 1/2 watt resister & a LED. I plugged them into the #1 & #12 pin & turned the key to the on position & the LED just stays solid & doesn't flash like it should so the I can get the code.. I'm at my whits end now.. So if anyone can offer some advice it would be great...
Old 04-14-2012, 03:52 PM
Girly TT's Avatar
Girly TT
Girly TT is offline
is the CEL on? pull the engine computer out, and check the capacitors, they are probably leaking. Common problem on the 91-93 model years
Quick Reply: 92 dodge stealth has NO spark... Help Please!!
