Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Starting Problems
Old Aug 23, 2005 | 12:38 AM
Richsta1's Avatar
Richsta1
Default Starting Problems
I recently had gas in my oil and my 1991 dodge would not start.. I was told to replace the head gaskets so i did.....
The car would not start so i sprayed starter fluid in and it would slightly run off that and then nothing again.... I imagine im not getting fuel to my pistons. i do know i have fuel going to my rail and that my injectors are not clogged.. does any one have any ideas?
Old Aug 23, 2005 | 12:45 AM
thestealth's Avatar
thestealth
Default RE: Starting Problems
Is it getting spark?? All harnesses up top plugged in?? Timing belt put on right??
Old Aug 23, 2005 | 02:03 AM
Richsta1's Avatar
Richsta1
its getting spark ill double check the harnesses plugs.... if the timing belt is wrong would the starter fluid still work?
Old Aug 23, 2005 | 12:16 PM
thestealth's Avatar
thestealth
Starter fluid?? If the belt was installed wrong, it would still do everything normal, except the valves would not be open/shut at the correct time. Have you done a compression check??
Old Aug 23, 2005 | 04:26 PM
Richsta1's Avatar
Richsta1
no i have not done a compression check. Thanks for the advice stealth ill try these things and repost if its still not starting thanks again!
