Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
what is this indicator light?
Old Mar 7, 2007 | 12:23 AM
Jeff7pt62's Avatar
Jeff7pt62
Default RE: what is this indicator light?
I think I found the source of my problem. The sensor is mounted on the bottom of the washer fliud tank. Mine is broken off the mounting where the wiring connects. You have to remove the battery, battery holder, then the tank should lift out. .....more to follow later on the "indicator light" saga.
[8D]
