Starting but is not ideling.
RE: Starting but is not ideling.
K...before i buy an AIC..these are the numbers I got from testing it while still installed.
35.4 between 1&2, 2&3, 5&6
38.7 between 4&5
Numbers seem a bit high....I tought that if the number was smalled the resistance was less....wich should have a negative inpact.
Dont have a clue what higher number mean in terms of performance.
Does it mean the AIC is bad ?
38.7 between 4&5
Yes, a smaller number indicates less resistance (ohms).
Your numbers are just a little bit high, but that could be the calibration of your volt/ohm meter.
Test procedure, per Stealth316
To perform this test, measure the resistance between terminals 2 and 1, between 2 and 3, between 5 and 4, and between 5 and 6. The resistance should be in the range of 28 to 33 ohms
I cheked the wiring diagram....and this is what the pins represent.
1. ECU
2. Fuel
3. ECU
4. ECU
5. Fuel
6. ECU
Considering my recorder resistance between 4 & 5 is almost 39...there is not enough curent going trough that coil to activate it resulting in turning off the fuel flow.
When i get the new IAC I will test both and compare the numbers while off the engine..dohh...that should tell me if its bad or not.
We need a chat room here
Tanks for the input everyone.....
1. ECU
2. Fuel
3. ECU
4. ECU
5. Fuel
6. ECU
Took one more messurement with the IAC of the engine...and while it was cooled...I got 31.4/31.4/32.4/31.4
Considering th resistance increasses while getting hot....and the given range of 28 to 33.....it seems like the 3rd coil passing the range by 1 ohm...causing it to no sending curent and opening the valve when the IAC is getting hot....ressson why after a test drive of about 2 miles it did shut down again.
So...I got the IAC on order....the stealth. my only car is my daily driver..and I need it fixed ASAP
I wander if coolant is a problem......the engine cooland circuit works right..keeping the engine temp just below the 1/2 mark....maybe could it be obstructed at the IAC section..somehow..and getting it too hot...?
O well....
O well....
just so you guys know, once in a great while mine will have trouble ideling, i just take the air filter boot guy off, and take some carb cleaner and clean out the intake, works like a charm and is under a buck for the fix. ( so far over 4 years, i've had to do it about 3 times, from carbon build up)
